I'm now thinking we should cut the pieces of skin separately using the template, cut the pieces of skeleton as well, glue them all together, and only after assembled and rigid should we put on the epoxy and fiberglass.
tony.latham wrote:I'm now thinking we should cut the pieces of skin separately using the template, cut the pieces of skeleton as well, glue them all together, and only after assembled and rigid should we put on the epoxy and fiberglass.
Exactly.
Glue them on the skeleton and then glass.
... I may temporarily screw the three pieces (each side) of outer skin (1/4" Baltic birch) onto the skeletons and route them to fit before cutting the bottom and ledge out of the skeletons.
...then draw two lines an eighth inch apart on the skeletons, cut between them with a jig saw, then use the template to route the skeletons to perfection.
Then I can take the scrap 3/4" ply, cut carefully to the other eighth inch line with the band saw
tony.latham wrote:Good looking wall skeleton.
tony.latham wrote:I cut the outside plywood with a jigsaw to within about 3/16" or so of my traced pencil line and then clamp it to the pattern and true it up with the router and a pattern bit.
tony.latham wrote:I think you're over-thinking this... But don't let me dampen your planning.
tony.latham wrote:...you can glue the blocking between the ribs leaving the 1/8" proud and trim them down using a patterning bit. (Anything to make more noise and sawdust.)
When I use a jig saw on thick material, like 3/4" ply, especially around curves, the blade tends to bend a bit, so the cut isn't perpendicular to the face. Probably something wrong in my technique...
tony.latham wrote:When I use a jig saw on thick material, like 3/4" ply, especially around curves, the blade tends to bend a bit, so the cut isn't perpendicular to the face. Probably something wrong in my technique...
Or maybe it's the blade? I find the jigsaw "close enough" for the skeleton.
redbicycle wrote:Looks great. I am doing the same thing right now-making the 3/4" plywood skeleton. Soooooooo much of the wood is removed!
tony.latham wrote:And for the record, I went to Plan B and did not attach the fenders to the walls on this teardrop ––as the pic would suggest. A fender catching a stump in a boondock site could easily damage the wall.
I went out and bought a pack of the up cut blades, and find them easier for this job.
tony.latham wrote:But right now we have trouble lifting just the floor ...
Build the dolly so you can get a car jack under the cabin. If you peek inside any of the commercial builders on Youtube such as Camp-Inn or So-Cal, none build on the trailer.
It's easier.
