Took a snow day off from work (after 2 failed attempts to go). Roads here were a complete sheet of ice. So I fired up the kerosene and electric heaters and begain framing the walls of my tear. I still have more to complete with the studs before adding the insulation and the white (dry erase) type paneling for the interior.
I noticed a slight bow on the front part of my floor that I can't straighten out. Because this part will be under the storage cabinet at the front, and also under the mattress, it shouldn't be noticable on the inside. I just want to make sure that its all square and level on the outside. So I am going to cut a strip wood to match the negative of the irregularity so that I will have a level piece to attach the bottom of the sides to.
I used glue and screws to attach the masonite to the studs. However, I found that masonite doesn't like to countersink the screws the way wood does. So I need to pickup a 1/4" countersink bit so that I can sink the screws flush with the masonite. I may also cover the sides with a thin sheet of foam underlayment (the type for floating wood floors) before I skin with aluminum to hide any lumps and depressions.
Hopefully I can spend some more time on Saturday. I am really getting cabin fever. If my trailer was done, I would be in Florida by now.
