RAYVILLIAN wrote:It's looking great Scott. Can't wait to see it down at LCG or maybe sooner. I've considered real strong on making our next one wider. One question are you going to make the double wall off set at the bottom of the hatch when it is down? Mike and I both did and I've wondered if it was necessary.
Gary
starleen2 wrote:Mike,
The wall and hatch construction will be 1/4 ply, 3/4 foam insulation, and 1/8 ply for the interior. The exterior will be fiberglassed along the seams and coated in resin to give it strength.
These T- nuts are what I’m going to used to keep the hatch locked in the upper position with a bolt going through the wood and into the T-nut. I’m thinking about embedding the matching stainless bolt into a wooden knob or plastic handle. When the hatch is down, regular enclosure clamps will do
