synaps3 wrote:GreatPumpkin --
Why not just freehand the profile? I think you'd be amazed at what you could come up with in an hour or so.
I agree with Sharon, that floor is impressive. I might have to borrow that idea for my build.
Thanks for the compliments. I'm really happy with how it turned out.
Well, somewhat I did. I really liked the profiles I mentioned above, and the Benroy. When I layed it out, I wanted a little more curve, and less flat spot on the top than the Benroy so I came up with the MOBIUS profile. I measured each point, connected the dots and then cut it out. Used my belt sander to smooth out the curves. I didn't use a pattern, but once I got one side done I used it to route the other side to an exact match.
This profile leaves me with only 2-1/2' of a flat roof. I'm planning on some kind a skylight/sunroof in that area. If someone used this profile for an 8' trailer they would have even less flat spot.
Here's the Benroy front profile. The upper line is a 19" radius found on the Generic Benroy. The lower line is a 24" radius that I found on another Benroy plan. I went with the 24" on mine. (That's my expensive, hi-tech beam compass pictured below)
This is the rear. Here the two layouts are the Generic Benroy (upper line) and the Grumman 2 (lower). I went with the lower one.
I'll see if I can get a picture of the whole side, but my work space is pretty tight. (Two
car? garage - yeah right. 4 Dirt bikes, 3 kayaks and a snowblower take up one side, my table saw, workbench, tools and the teardrop take up the other side)
