bohemian wrote:Hi Len
Is that Masonite your using for the outer sheeting as well and if so will you also paint to seal it before putting the roof material back on. With all my years of experience in the wood working trade I have never worked with Masonite. I was just wondering how it will hold up. - Wayne
len19070 wrote:bohemian wrote:Hi Len
I love Masonite. You can almost tie it into a knot and it won't brake. Can't say that about a lot of Plywood's. I really like the way the back of the sheet takes to gluing as well.
Its been around for years and I've seen it used outside painted in one application for over 35 years.
The one thing you have to realize is that its still a thin material and must be used as part of a "panel system" when Laminated, screwed & glued to other materials the stuff makes a good sheathing for a truss system... and a curved application is even better.
All this said, any thing will rot if it gets wet.
I don't bother to seal the roof because I use a single sheet of EPDM rubber that overlaps everything..the sides and front. Plus I don't know how sealing it will effect the EPDM glue...It must be applied to a Pour-us material.
The areas below the roof I use Thompson's water seal or Parks pigmented shellac.
Len
CAJUN LADY wrote:Len, sorry to hear about the bronchitis. I too seem to get it around this time of year but it showed up earlier this time. Over and done with! Sure am enjoying your build. Hope you get to feeling better soon.
grizz wrote:CAJUN LADY wrote:Len, sorry to hear about the bronchitis. I too seem to get it around this time of year but it showed up earlier this time. Over and done with! Sure am enjoying your build. Hope you get to feeling better soon.
Could it be that you guys have some allergies to flower pollens this time of the year.
I never had allegies till I moved to the UK, now I take antihistamines for about 4 months every year, and do very well.
