bve wrote:Steve, I notice on this build you have framed in and done all the blocking for the door prior to cutting the opening, on the Lil'Diner build and if I recall correctly the Rondack Lodge you had cut the doors from the skins prior and then framed them.
I'm curious as to the change in 'process' so to speak, what was the driving factor? Is it just a matter of trying something new? I can see there would be less waste material with this method.
Burke
Steve Frederick wrote:By building the door in, then cutting it out, I would have a door that matches any warp in the wall that might exist. Make sense?
