jdarkoregon wrote:Nice build, thanks for the great sequence of images. You tell a great story.
John
Weirdnerd wrote:It all started on a trip to lake McConaughy in Nebraska, we were lured by a friend who had a sailboat with the promise of a nice lake, with sandy beaches, crystal clear water, and a nice camping.....everything was true but the wind, the frogs, the huge biting flies, and a massive category five thunderstorm that soaked us inside the tent, my wife said she had it with the tent and unless I find something else to camp, she was out.
Enter internet, I needed something like a popup camper, but my Honda was limited to 400 kg...humm...search search..wait...what was that?...a teardrop camper...humm, looks cool, a little small... I can make it a little different, for the three of us...I may be able to pull that with the honda......here is the story....
First, with my helpful neighbour ( he is a veteran of Craigslist) we found a dilapidated popup camper, the thing towed nice, but ( caveat emptor) when I removed the siding to inspect, it just fell apart like a deck of cards, that made it easy, tear the whole thing apart and sell the metal to fund some of the new material...
then I started building the floor..... but first , I sanded the whole frame and put a couple of coats of rust stop primer, and a coat of black oil based spray paint...also removed the bumper, that was about one foot longer than what I needed..
then the vinyl flooring, was on sale at Big lots, 10 bucks a box..only four boxes needed...
attached the floor to the frame with 10 1/2 inch diameter hardened steel bolts, that is going nowhere...
then I got creative with the cardboard, make a template for the walls....that was something actually funny....
With the templates I made the walls, my wife was almost in tears about the amount of sawdust it generated.....hence " tear drop".
attaching the walls by myself was worth a comedy video, finally I stuck a couple of screws to the walls, to set them up, measured several times to make sure they were parallel, and at the same location on the frame...fell a couple of times in the ice, and scraped my elbows sort of bad..., another 10 3/8 inch diameter hardened bolts there....
after that, I started the internal skins, lots of glue and brass nails ( like the ones they use for boats).
After that, I painted the whole bulkhead interiors with elastomeric roofing paint, to prevent dry rot.... ( the floor got the same treatment, all inside and outside)
then...insulation, 1.5 inch styrofoam, set with silicone on the edges, to prevent rubbing and squeaky noises....
Then the exterior plywood ( Luan,) 1/4 inch thick....
after that, I set to build the clam shell....
The interior bunk...on top of the wheel wells...
the window...it's 3/8 of an inch thick on a 3/4 birch plywood frame, routed to fit the window flush...
after that I started to build the cabinets, with some nice pine obtained from "Alley mart"...somebody was dumping a water bed, and the wooden frame was excellent for my purposes....
the sink is a stainless steel kitchen bowl, from wally martinez, 7 bucks flat, beats having to pay 120 dollars for an RV sink...a dremel tool was good enough to trim the hole for the drain...
Then played a little to install the shock struts...
and coated liberally with several coats of Exterior polyurethane, to seal the whole thing up, after that, my neigbor let me use his garage to pait the exterior with marine paint, color chosen by my wife ( I wanted white)
had to install one of those fancy " make a breeze" fans, they work nice....
Recycled airplane reading lights...
custom made switch plate for the lights and the fan...
Power inverter and 12/110 v outlets...
Finished the kitchen...
The interior...
sleeps 3, and it's something very comfortable, even my wife is surprised ( she is my resident QA)
on my first move, I banged my hand quite painfully between the trailer hitch and a tree...
I went to weigh it...surprise!..1740 lbs...almost 1000 pounds more than I was thinking....( In my defense, I just winged it, no plans whatsoever, so my imaginary weight didn't stand a chance against real world weights...)
so I had to buy a truck that could pull it...
and search for a tow hitch on a junk yard...
took me a couple of hours to make the pig tail and wire the truck for the trailer lights...
and that weekend we went camping....everything was like " test for problems"...but everything worked as advertised
and the first coffee from the kitchen tasted like accomplishment!..
so far we have gone five times camping with it, and I am feeling quite happy of having decided to build the teardrop....I may have to build another in the future....I have learned a lot during this adventure.
