KCStudly wrote:Nice.
RandyG wrote:Great start! I like your floor dolly, I may have to use the idea so I can easily move out to the driveway and back to the garage at night.
mallymal wrote:That's a lovely elegant simple profile. Good work
Shadow Catcher wrote:You might want to consider 5086 or 6061 marine grade. The problem I ran into is the finite modulus of elasticity of aluminum. There was a lot of flex/bounce at the point where the frame 2X4X.25 rectangle went under the body of the trailer. This is where #1 MM failed, Both sides snapped. These are pictures of the original construction minus the additional bracing.
You might want to check on what is used for horse trailers, not much that is more corrosive on aluminum than horse pee. Boat trailers are also made using aluminum.
RandyG wrote:Be aware of fatigue with the aluminum.Shadow Catcher wrote:You might want to consider 5086 or 6061 marine grade. The problem I ran into is the finite modulus of elasticity of aluminum. There was a lot of flex/bounce at the point where the frame 2X4X.25 rectangle went under the body of the trailer. This is where #1 MM failed, Both sides snapped. These are pictures of the original construction minus the additional bracing.
You're tongue isn't as long as his was and your A-frame goes under the floor frame so it shouldn't be a issue. You also have more welding surface area. Are you the one welding it?
I hope Shadowcatcher doesn't mind me sharing his post but thought I should spread his lessons learned.
KCStudly wrote:You're going to be done and camping before you know it. Good work!
