- door handleinside.JPG (108.19 KiB) Viewed 1272 times
I just read back through this thread and realized I didn't say anything about my doors. IT feels like the doors and door jams took as much time as the rest of the trailer, not even joking around.
I talk about how the door jams are built and I have pictures earlier in this thread.
This is how I built the doors. I ended up using the blanks that I carefully cut out with a template out of the sides of the trailer (see the beginning of this blog). I used one blank to make a table to work on. I cut out another blank and then screwed it to the table and used a router bit to make the door 1/8" smaller. Then I put wax paper under it and used short hair resin to rebuild the 1/8" outside. Then used a 1/2" flush trim bit to cut the door back to the original size. The first blank that I used as a table is the template for the outside of the doors. So the outside edge is now waterproof and can be left exposed or covered with aluminum with no fear it will ever rot(provided you seal your screws properly).
Then I used resin to glue another 1/2" birch that will be the inside finished surface. I used a router to inset the sealing surface that the flush windows will sit into. Then painted 4 or 5 coats of resin on the outside. I gave it a hand sanding with 80 grit to roughen it up to accept the gel formula Weldwood contact cement. Sam procedure in attaching the aluminum; scuff up both surfaces with 80 grit. contact cement rolled on the door front and the aluminum. wait 15 to 20 minutes between each coat. On the first two coats I waited until it was completely dry. The last coat that will be the contacting surface, I waited until just before it was completely dry. Then used 3/16" wood dowel rods spaced 6" apart and starting at one end removed them and used a J roller with all my 135 body weight pushing down onto it. The aluminum I used is .050" mill finish. Mill finish was all I could find in 5' by 12' sheets. For the record I would have used anodized if I could find it in that size. I will keep my trailer waxed with some good pure carnuba wax to try to preserve the finish. And of course store it indoors when I am not using it.
