After I turned the roof over to work on exterior side I am puzzled whether I got any amine blush on the surface as I did not finish the lamination with second and third coat while the epoxy was still "green", being new to large surfaces lamination, I did not know better at that time. Now I washed its rough surface with water the best I could as per West Systems article recommendations (
http://www.westsystem.com/ss/assets/Uploads/Ew20Contamination.pdf), but the water still beads on the surface as if it is still contaminated according to the article test..
, but it looks clean and there was nothing in the shop that could contaminate it, except as I mentioned the "potential" of amine blush appearance on the surface due to air moisture. Air in Alberta is 50% relative humidity or less usually.
I think I would go ahead and fill the weave with second and third coats of epoxy as is, I did everything I could to clean it.
Maybe Atomic77 will help with advice, I sent him a PM on this.
