Stainless Steel Micro-Airstream behind motorcycle
90: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Mar 22, 2014 12:26 pm
The door - a difficult task !
Bending a tube by hand is no problem - but bending a tube exactly like another - that was no fun !
Yesterday I started with the piano hinge and the upper frame tube and then bent the two gullwing tubes :x
But after two hours they matched the box shape and I could rivet all together with stainless angles.
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
Re: Stainless Steel Micro-Airstream behind motorcycle
Postby Martiangod » Sat Mar 22, 2014 4:35 pm
Going to be a true spectacle when its done, are you going to use a hydraulic strut so it can hold in the upright position? Or something more ingenious ?
Keep up the awesome work, you will be camping soon I think :relaxing:
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby ST1100 » Sun Mar 23, 2014 5:02 pm
Martiangod wrote:Going to be a true spectacle when its done, are you going to use a hydraulic strut so it can hold in the upright position? Or something more ingenious ?
Hope to find a hydraulic strut matching the weight !
1977 Eriba Troll
ST1100
Images: 199
91: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 23, 2014 5:05 pm
Before giving the door a skin I installed today the first two windows and the marker lights to give the trailer a face.
1977 Eriba Troll
ST1100
Images: 199
Postby ST1100 » Sun Mar 23, 2014 5:10 pm
Drilling the plexiglas was easy, but to work careful needs much time !
And fastening the nylon safety nuts on the short bolts needs longer arms than I've got.
For the other windows I need a helping hand.
1977 Eriba Troll
ST1100
Images: 199
Postby sagebrush » Tue Mar 25, 2014 9:01 pm
:thumbsup: :applause: :thumbsup: :applause:
Will
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
92: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Fri Mar 28, 2014 3:07 pm
Today I started installing the Opel Rekord taillights which I converted to LEDs.
And then I fitted the plexiglass roof window between the frame tubes and drilled all the holes for the 4 mm stainless bolts.
Then sealed it with sikaflex and fastened the 42 nuts and bolts around the skyview.
1977 Eriba Troll
ST1100
Images: 199
Postby KCStudly » Fri Mar 28, 2014 4:08 pm
Very nice! :thumbsup:
93: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 30, 2014 4:41 pm
Yesterday and today I installed the windows in the sidewalls with a little help from outside.
Then I made a frame from plastic tube for my roof vent, because my roof skin ist too skinny to fill the space between inner and outer frame.
and glued the vent in with sikaflex and connected the frames with screws.
This is the view from my pillow skywards.
1977 Eriba Troll
ST1100
Images: 199
94: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 30, 2014 4:51 pm
After finishing the windows the door frame was my next task.
To get my door waterproof I had to add two stripes from aluminum to get space for a self adhesive rubber door seal and a inner frame where the door can fit inside.
The spacer is 20 x 2 mm and the inner frame is 30 x 2 mm.
A lot of drilling, clamping and finally sealing with sikaflex and riveting the first part.
1977 Eriba Troll
ST1100
Images: 199
95: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 30, 2014 4:54 pm
And that's todays result !
1977 Eriba Troll
ST1100
Images: 199
Postby KCStudly » Sun Mar 30, 2014 6:26 pm
Your door seal flange is a master's work of art! :thumbsup:
Postby S. Heisley » Sun Mar 30, 2014 8:13 pm
Beautiful work, as it always is! :thumbsup: :applause:
Postby ksmack01 » Sun Mar 30, 2014 9:01 pm
Ive followed this from the beginning. I can only muster 3 lil words......Hoe-lee-cow :thumbsup: :thumbsup: :thumbsup:
ksmack01
Images: 61
Postby jonnyo » Sun Mar 30, 2014 11:29 pm
amazing work!!!! i wish i could do stuff like this!
keep posting pictures!!! i m learning so much!
jonnyo
