absolutsnwbrdr wrote:I'll have to look around. The inside diameter of that bearing is 25.4mm. The bearings that come from Harbor Freight are 25mm. That .4mm difference is almost nothing, but its still not the same. I'm sure it would be fine for an emergency hub-swap but I dont know if I'd run it full time.
Cliffmeister2000 wrote:You can order parts directly from Harbor Freight. I have ordered items several times. They can be slow, but you will get the right part.
If your trailer is the Model 94564 1,720 lb trailer, then call 1-800-444-3353 and tell them you want part #20.
Deryk the Pirate wrote:Hey Zach, Great build. And thanks, you gave me a better idea for a tongue box then the $79.99 metal HF one. Will be headin to lowes tomorrow to pick it up. I was planning something the same, a place for the battery and charger and a powercord for my air conditioner. Im still building but its got to be campable by the end of april for a party Im going to.
S. Heisley wrote:Very clever, Zach, and with latches, you might even be able to add padlocks. Or, as an addition safety precaution (if you feel you need it), add a metal strap, anchored from the deck's underbelly to the outside edge of the chassis frame, where the strap might be padlocked in place. I have seen others where they make a drawer that slides under but yours, being hinged and latched, seems like it would be more secure.
Deryk the Pirate wrote:someone told me we arent building campers were building prototypes... and it makes sense since its always something new to add, and most of us are eager to start the next one lol
