KCStudly wrote:A little bad luck can't ruin a good trip; I'm glad you had a chance to show off your hard work; well earned pride.
I hope the window break wasn't a rock thrown up by your own TV. Maybe kicked up in a turn or ricocheted back off the trailer fender? If so, maybe mud flaps or a smaller version of those clip on curtain things you see the 5th wheel guys using would help; something removable that you don't have to look at when you aren't towing. The Aussies have a bunch of rock protection ideas, too, maybe look into those.
dales133 wrote:Worst luck dude, sounds like it can be fixed without to much drama though
KCStudly wrote:So it looks like it took a stone on the edge of the glass?
Those windows look similar to mine, except they are larger. If they are Heir, I believe they are intended to be flush mounted, or at least have the capability to be as there is no frame or seal around the outside edge of the glass. It was a lot more work and I had to make a router template to make another router template to cut the recesses in my doors, but after seeing this I am feeling that it was worth it.
Let's hope that you just got unlucky the first time out and that it is not a recurring problem.
M C Toyer wrote:From your photo it appears your window was tempered glass.
To replace tempered a new glass will have to be cut then sent out for the tempering as it unlikely a shop will have that capability. I suspect the cost will be considerably higher. They may offer an alternative of laminated safety glass or even Plexiglas that could be cut at the shop, but would probably not match and the Plexiglas is not a suitable option due to scratching.
Have you considered contacting the window manufacturer or vendor of the window to see if replacement glass is available off the shelf? Would probably save money and time and definitely avoid aggravation if the shop didn't get it right the first time. You could still use them to do the actual glass installation.
It might even be cheaper to get a complete new window.
