KCStudly wrote:Once it is back in the shape you want, adding some stiffening ribs (foam ribs laminated in place), akin to the old station wagon roof ribs, either on the inside or outside, would help stiffen things up.
Also, have you considered post cure heat? Supposedly elevating the epoxy temperature to 160 - 190 degrees and soaking it for a while using lamps (or sunlight) can add quite a bit of strength and stability.
KC, yes post cure is definetely an option, the only thing to be aware of it outgassing that rigid foam or whatever minor trapped air inside the laminate can produce. I found one time hard way that the additional applied heat, after the layup was done, has created some delamination around the small penetration holes, I described it some time back in the build thread. I think post layup elevating the temperature would work reliably with vacuum applied, which is not an option in this case. I will though maintain 70+ F degrees when I do this roof fix to ensure complete cure. It will take some time. Having said that where I will be using the jig to press things together, elevation of temperatures will be actually a good idea, thanks!
