Another score (evilBay this time). An RV door complete with lock and keys. It was advertised as "new", but it looks like it could have been a pull? Seller
bottomdollarsurplus. Some of their stuff is advertised as "pulls" some as "new". I'm pleased with it though and the price I paid.
As bought.
They are too large for a 48" wall, but I knew that when I bought it. It still gives me a great frame, lock, seal, etc.
Here I've cut the frame down and finally made the cut in the wall - another reason I hadn't previously installed all the spars, I've been entering and exiting from the front while I decided what to do about a door.
Door frame cut down.
The door was a little more of a pain in the butt to cut down and get the angles cut just right without fully removing the frame from the door sandwich. I removed about 7" from the door before putting it back together.
Door cut down. Actual door opening now around 29" w x 35" t
Door isn't fully installed, just propped in place. I'm planning on removing the outer white fiberglass layer and replacing with aluminum when I skin the teardrop. I also still have to remount the lower hinge. I haven't decided if I want to: 1) leave the frame white, 2) paint it black, or 3) remove the paint with aircraft stripper and polish the aluminum.
Decisions, decisions... Sometimes I think I spend more time faffing about than actually working on the teardrop.
I actually picked up an identical lock and hinges at the same junkyard I got the sink from. They were off an identical door, but the frame was just too destroyed to salvage.
