Some progress tonight!
I sanded the roof seam down after hitting it with some filler this weekend.
I also sanded both sides again, gave a light wipe-down with mineral spirits, and gave them their final coat of Urethane.
After cleaning everything off and giving it a once over, I then rolled the RV EPDM rubber roof out over the main roof.
Since my hatch is not installed yet, I ran three screws into the wall framing about 7 inches below the rear edge of the roof, below where the hurricane hinge will be located. This held the rear of the skin in place while I laid it out where it needed to go.
Once I got the roof aligned, I flipped the front back up and over the back so I could apply the EPDM Latex adhesive.
This adhesive allows two forms of application.
Dual surface contact, or single surface pressure.
Since I was doing this myself, I opted for the latter, where you coat the wood surface, immediately lay the EPDM down, and smooth it. After approximately 30 minutes you brush the roof firmly with a push broom to press everything into place.
I applied putty tape along the very edge of the roof before laying the edge of the EPDM over the side. I pressed the EPDM into place over the putty tape, and then began measuring the front radius for the roof edge molding.
My front radius is 24 inches, and since my walls sit flush with the top of the trailer, I have an idea in mind for the lower trim along the trailer.
I have some T6061 1/4" thick by 3 inches wide that will go side to side across the trailer just below the edge of the plywood. The EPDM roof will come down below the wall line and overlap the front of the trailer frame with putty tape underneath it. Then, there will also be putty tape over this behind the T6061. This will be attached using self-tapping screws into the trailer frame and provide a weather tight seal for the very lower front edge of the trailer.
Back to the topic of the radius... The roof edge molding is powder coated extruded aluminum, and since I want to overlap the T6061 at the front lower edge, I measured 27 inches from the end of the roof molding, and began marking every 1 inch. A total of 36 cuts were made.
This allowed the roof edge molding to contour to the frame. It overlapped the EPDM flap sticking off the side as well.
I applied another strip of putty tape immediately between the EPDM and the roof edge molding, and then ran some lathe screws through the molding, the first layers of putty tape, the EPDM and the second layer of putty tape. Why Lathe screws? They have a flat, wide head, rather than a tall head.
Then, I trimmed the majority of the rubber back (as seen in the picture of the cuts above, and the following picture.
After the EPDM is trimmed back, I will mask the wood and roof and touch up the cuts with some white "Appliance" enamel, then I will run some clear "50 year" silicone caulk into the cracks as well as under the edge of the trim against the wood.
