Major milestone completed today; the exterior plywood sheets are now permanently attached. The wiring is now permanently ensconced inside the wall sandwich (1/4" ply - 3/4" blocking - 1/4" ply) and I'm through with adding any "just in case" blocking. I applied the first coat of poly 2 days ago. It was a bit gusty but I figured I could spray OK between gusts. I managed to apply the Gloss Spar Urethane (oil based) with no issue but when I set the sheet aside to dry, the wind kicked dust and debris into the wet poly and royally screwed it all up.
I set the sheets inside the garage, let them dry and lightly sanded them next morning. Yesterday was less windy so I was able to get three more coats of poly on before letting it dry overnight. It looks great! Nice depth with a smooth, glossy feel. The HVLP sprayer from HF works like a champ - easy set-up (slightly diluted poly with mineral spirits), consistent application, and easy clean-up. Balls deluxe.
These pix show my spraying station and the final product drying in the sunshine. The blue tape kept poly off the areas where the PMF will overlay the edge.
I permanently attached the outside sheets this afternoon. Applied PL Premium to all the blocking, screwed the perimeter (will be covered by wood trim) and placed clamping cauls to hold down the field. I also ran my trailer 7-wire and battery wire through some 1" PVC conduit from my galley junction box to the front of the TD. My TD battery box will be housed on the trailer tongue to even out the weight distribution. Finished up some trailer marker wiring before calling it a day.
Overall, I'm happy with the progress. Good weather has helped immensely. Next steps are prepping for sheathing the roof, build doors, and construct the hatch.
QUESTION: I want to shave 1/4" off my sides in the hatch area to better fit the gasket material. Whats the best way of doing that? Belt sander? Router (how)? Thanks!
