toconnor602 wrote:Its looking really good!
Mushin wrote:Good looking build!
Word of caution as it looks like you have the same stargazer window I have. Mine leaked alot! Not around the outside edge but where the rubber and glass meet up. May wanna test prior to finding out the hard way and seal up before final install. Hopefully yours is good to go though!
Keep up the great work!
KCStudly wrote:I used a hand plane to true up the butt crosswise joint in my ceiling skin, then backed and glued the joint together under clamp force before installing.
Since it is too late for that, here are a couple of other ideas;
First, don't forget by the time you get the outside all sealed up there won't be any light shining thru so the gaps won't be anywhere near as noticeable.
Second, once you get your front shelf or cabinet in, it won't show as much.
Third, if you want the "unsightly" gaps to disappear, it is far easier to "celebrate" the repair by hiding it in plain sight, than it would be to try to blend it in so that you don't see it. In other words, consider adding a nice dark trim strip (or a lighter one) of different species to cover the gap. Put a little round over or ogee detail on the edges if you like and match the inside corners with 1/4 round... then carry that same trim theme subtly throughout the build, using the same finishes and highlights on your cabinet doors, drawer pulls, whatever. Everyone will think you planned it that way from the beginning!
antalog wrote:Yeah, its a brand new DeWalt. I bought from HD, didnt start using it for a few months and now its outside the return date. But Im gunna dig around and see what I can find.
ELM wrote:Are you using to fine of blade maybe. I've used to fine of blade before on wood and it got hot and wouldn't cut straight. I wood think a new saw would cut good.
