So, I got my battery tray cut into the floor. It looks good.
It looks crooked and off center, but it isn't. Measurements were taken several times prior to the first cut.
The "below decks" view.
Slightly angled to show you the trailer axle height in relation to the bottom of the battery box. If the trailer axle can clear it, so can the battery box.
One battery inserted to see how it fits and looks.
The plywood piece that came out of the hole that was cut will be trimmed down to fit inside the battery box opening. I have picked up several pieces of 1/8" thick by 1.5" wide bar stock, and will be attaching these to the plywood plug. This will provide a flange all the way around the edge that I can gasket and seal the box from the cabin.
The sections below the floor of the battery box will have polycarbonate mounted to them and sealed with silicone. This will provide a bullet proof shield to protect the batteries from rocks, etc, and help enclose and protect the batteries and keep dirt/water, etc from getting in and gunking things up.
The floor does tend to flex the tiniest bit with the tray sitting in there. I will be mounting another piece of angle iron underneath the floor against the box and the bottom of the floor. Bolts will run through the flange on the battery box, through the floor and through the angle iron under the floor. When tightened, this will sandwich the floor, stiffen the support, and provide a surface that I can seal to prevent water from splashing up into the cut edges around the box.
In the meantime: White EPDM Rubber Roofing gets dirty FAST...
I have a tire cleaning product called Bleche White. It works fantastic for cleaning white wall tires, or raised lettering, or just scrubbing a tire clean before protectant is applied.
In this odd angle photo of my hatch, you can see the dirt and scuzz built up on the EPDM from when I installed it.
10 minutes later and that same hatch looks like this (albeit, still wet).
Bleche white, sparingly applied to JUST the epdm roof, then scrubbed using a scotch brite pad, then rinsed thoroughly just makes it gleam. The white roof looks brand new (cause technically it is....) and really catches the eye.
