MeelisV Tear DIY compressor ref.
Re: cabin rebuild - aluminium frame
Postby MeelisV » Sat Jun 09, 2012 11:25 am
more then some days but here is two pics.
new windows
with blind and insect protection
A woman has the last word in any argument.
Anything a man says after that is the beginning of a new argument.
MeelisV
Images: 105
Postby 2bits » Mon Jun 11, 2012 10:06 pm
MORE MORE! You are doing a great job here! Thank you for sharing it with us!
Thomas
2bits
2bit Member
Postby KCStudly » Mon Jun 11, 2012 11:35 pm
+1. Very nice indeed. :thumbsup:
Postby MeelisV » Tue Jun 12, 2012 2:00 pm
ok more it is then
opening
outside frame
outside frame inside view
inside frame
profile view
two doors open with windows
close view with alu.blind curtain
MeelisV
Images: 105
Postby RandyG » Wed Jun 13, 2012 3:46 pm
When this is done it will look as if it came from a manufacture's factory, looks amazing!
But you said you were going with stainless rivets... I would advise you to go with regular AD rivets. For one, it will possibly corrode faster with SS on alum. And two, it is a standard on aircraft to use the same material that is on the shop head of the rivet, in your case it would be alum. SS rivets may cause additional damage during installation or if something fails. Search for Cherrymax rivets, they are a blind fastener much like pop-rivets but much stronger because they have a locking collar to keep the stem in place. Just giving some advise... I work with alum ALOT.
Randy
RandyG
Images: 115
Postby MeelisV » Thu Jun 14, 2012 4:48 am
thanks RandyG
my plan was - use first alu pop rivets and when all is right then replace with ss rivets.
and if not then its easyer to remove alu rivet then ss rivet.
and because i use Sikaflex glue too then i think that i will not replace alu rivets at all.
yesterday there was last bit floor insulation.
now there is interior works - first the cabinet in front.
i use white plastic (red one is protective film)
MeelisV
Images: 105
Postby MeelisV » Thu Jun 14, 2012 1:45 pm
some new pics
MeelisV
Images: 105
Postby KCStudly » Thu Jun 14, 2012 3:36 pm
Very nice. The good just keeps coming. That red sure looked good, wish you had picked that, but the white is nice, too. :thumbsup:
Postby MeelisV » Mon Jun 18, 2012 2:26 am
first day out from garage
MeelisV
Images: 105
Postby MeelisV » Sat Jun 30, 2012 10:55 am
front corners
and wiring
and my new sunsail
if there is good weather then will make pic. with my trailer
MeelisV
Images: 105
Postby KCStudly » Sat Jun 30, 2012 7:48 pm
We need more on your wiring.
Sure looks like a lot of cable.
Good job! :thumbsup: Keep it coming. :thumbsup: We are enjoying your build and skills! :thumbsup:
Postby pappaw » Sun Jul 01, 2012 10:03 am
wow, that's one classy camper :thumbsup:
cheers :beer:
Image Cheers from Granny, Pappaw, and Cocoa (the Dachshund) Image
pappaw
Images: 14
Postby Vedette » Sun Jul 01, 2012 10:34 am
What are you going to hook all of those wires to?
You might be restricted to camping under Main Power Lines or next to an Electrical distribution plant so that you don't cause a "Brown Out" in nearby towns??????? :R
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby MeelisV » Mon Jul 02, 2012 3:11 am
there is always good when you have some spare cable
there is plan that i have lights in front cabinet, in front sleeping area right and left side, ceiling 2x and back of sleeping area right and left side, outdoor on top of doors, under the hatch2x
and then some 12V and 230V socket in sleeping area and in galley, stereo/speaker, TV ....
:R
in my old tear there was no cables and no lights and no sockets and now i know what i want
there was no windows what could be opened and no roofwindow
no gas or battery - so thats why the new one maybe like overkill
MeelisV
Images: 105
Postby MeelisV » Sun Jul 08, 2012 9:04 am
galley work
first the insulation
then the inside cover plywood peaces
glued in
arces are finished with alu. U-profile
under frame cover
cooler box instalation
corner for electrical
between fridge and electricalteher is room for food and ...
MeelisV
Images: 105
