skinnedknuckles wrote:Jeremy,
Did you get a price quote for your axle from a place in Madison or Edgerton? The guys from Edgerton were able to give me a good price when I had an axle made to my specs. The guys downtown at the steel place know me, they would get a kick out of hearing about another teardrop coming together in town, that is were I purchased my frame steel , diamond plate and aluminum sheeting , just ask them if they know a guy named Paul that has army trucks, jeeps ,a rat rod and is building a teardrop camper . Good luck on your build . It sounds like you are starting to get things together. Like TimC stated about Mikes' saying , its true once its done and you sit back or in it and look at your work the price kinda is forgotten but the workmanship is there to stay .
Have fun making dust and woodshavings,
Paul
Paul,
I am super excited I am getting out of my Forester payment and buying a 2010 RAV4 Sport V6. I have been worrying about towing weight abd lack of extra money for the build. This rig solves both.
I just finished adhering the last spacer to the cross beams. The HDPE plastic was a little pricey but I also got 2 sheets of 3/8" 4'x10' osb to make projects with. I have the tongue mocked up in place. I'm going to grind off the ball hitch mount on the tongue bracket... When I get my hands on a grinder and then drill holes for two bolts through the top and bottom tongue brackets and tongue.
I will have to check out the place in Edgerton for an axle. I'll get a picture up when I get the tongue mounted.
Jeremy
