Another few days to get to day 13 but I have been busy. I've been working on the core for the walls. I'm making them out of 1X hemlock and my first step is to rough-cut the end curves for both ends.
Here are a series of photos from that process. I haven't seen others quite do it like this but it has worked out pretty good.
This will take a couple of posts because I have more photos than will fit on one post. There seems to be a limit and I haven't figured out how to add more.
First I laid out the wood and cut the angles to form the curve.
- cut.jpg (23.41 KiB) Viewed 2818 times
Next I cut biscuit joints into each end of each piece.
- biscuit.jpg (44.31 KiB) Viewed 2818 times
Next I hot melt glued cauls onto each piece about 1 1/2" from each end.
- clamp1.jpg (22.82 KiB) Viewed 2818 times
Ok, onto the next post!
