ELM wrote:If you have an air compressor you could buy a cheap spray gun from Harbor Freight and spray your clear finish on. http://www.harborfreight.com/air-tools. ... goryExpand You might need to thin your clear a little bit. If it's water based thin with water.
ELM wrote:When I spray with water based paint in my paint guns I clean them with warm water an then run some paint thinner or lacquer thinner through to get the water out of the gun so it doesn't rust. Most paint guns have steel needle and seats.
toconnor602 wrote:ELM wrote:When I spray with water based paint in my paint guns I clean them with warm water an then run some paint thinner or lacquer thinner through to get the water out of the gun so it doesn't rust. Most paint guns have steel needle and seats.
How much are you typically thinning the water based poly?
ELM wrote:toconnor602 wrote:ELM wrote:When I spray with water based paint in my paint guns I clean them with warm water an then run some paint thinner or lacquer thinner through to get the water out of the gun so it doesn't rust. Most paint guns have steel needle and seats.
This might sound funny but I watch how it drips off my stir stick. If it just runs off in a stream it's to thick. If it just drips off it's to thin. What I look for is when it runs off then starts to drip off the stir stick. Try starting with 4 parts paint to 1 part water when using water based paint. When it sprays out of the gun you want a mist. Maybe watch some you tube on mixing and spraying paint. We are off on a three week trip to Yellowstone and then to Wisconsin and then Grand Canyon in the Teardrop.
Graniterich wrote:I have sprayed 12 walls, I have the 20oz HF sprayer and do not thin water based minwax. Takes seven plus coats,but feels like plastic!
Users browsing this forum: Google [Bot] and 22 guests
