I took some scrap ply and made temporary drawer fronts this week, to check fit, alignment, etc.
good thing I did too, because it turned out I had a little error on the height of the supports on both sides, that looked innocuous enough until I saw the changing size of the gaps from the tops of the drawer fronts to the bottoms of the counter and stove cubby floor. My options were to 1) make trapezoidal drawer fronts, or b) shim the sides. OK, technically, I could also 3) ignore it, 4) start over and build a new teardrop, or 5) fly it inverted and see if things shake loose.
5 didn't work, so I went with the shims (
1/8 inch shims! ). Looks okay now, I suppose. What I should have done, I now realize, was, instead of simply drawing a line on the sides of the galley and holding the supports to that line while drilling holes for the screws with the other hand, I should have taken some of the scrap ply and made some temporary braces for the supports to ensure they went in at the correct height.
Of course, I also have galley sides that come together slightly at the back
We were simply going to use trim here, but I think we may make one of those holders for commonly used items like Tony has, except instead of confining it to the back, we'll make ours L shaped. Or maybe a small spice rack that is removable to put in a bear box. (Which spices do bears like, and which repels them anyway? I could see some of those Northern bears really getting offended after trying some of our Hatch green chili spices.)
