Mr. Lahey wrote:Jeremy,
Great work so far!
I'm a newb here from Delavan WI and will enjoy following your build.
Thanks to otheres on the thread for the mention of where to source parts/supplies in our area.
Looking forward to starting my own build in the next few weeks.
Been inspiring to see a neighbors progress
noseoil wrote:I think the ""best" option is the one that costs the least & still gives a good functional panel. Since the plywood is just a frame (the skeleton for your build), find the flattest, cheapest type & join the edges for the size you need.
I just used wood dowel pins & glue to hold mine together long enough for the inner skin to actually glue & hold it in place. A pin at each joint in the frame is plenty. A butt joint in plywood with glue & a dowel will make a cabinet maker cringe, but it's the skin that locks it in place the way an OSB panel locks a wall together in home building once it's nailed to the 2x4's. Once a skin is glued in place, you'll be surprised at how light & strong the panel is. Prior to skinning, be careful moving it around as it can break at a joint from its own weight, if you aren't careful. Just my $0.02 worth...
skinnedknuckles wrote:Jeremy,
I used 4x8 sheets of marine grade plywood to make my sides. At 9' 5" my seam is at the rear in the galley. That way ,once you put the cabinets in, the seam is strengthened. I made a spline out of 7 ply 1/4 " plywood epoxied into a groove cut in with my router. It should be plenty strong enough. If you were to look at it you could not see it as I also have a 3/4" plywood with holes cut in for lightening and then I covered it with 1/8" Baltic birch plywood. When gluing the spline and plywood together I used 2" x 2" angle iron for a backer to clamp to that made sure that the whole thing stayed flat and straps to pull it together ( not tightened too tight but just enough so things stayed flat and together )
Have fun
Paul
Users browsing this forum: smeerkees and 14 guests
