noseoil wrote:Iain, looking good now. Man, that's a lot of holes to drill. Hope you had a good supply of new bits, or a good sharpening system to use on the old ones.
I used a router with a 1/2" flush cut bit (12mm 2 flute cutter, pilot bearing on the bottom side) to trim my panels once they were attached. Rough-cut the side panel 2-3 mm too big, fasten in place & then trim to exact size once it's in place by shaving the excess material with the cutter. If you have a router it might make things easier, since you don't need to be as accurate in the initial cut & the match is a perfect fit once the panel is in place.
This is a wonderful build!
Iain Hall wrote: ...when I built the car in my post signature because I did those at two inch centers but for this I'm doing them at 3 inch centers...
I think that's almost as much work as sanding fiberglass resin smooth on plywood. Your build is going to look great!
