I know everyone believes that if glued up correctly that this could not happen, well after research and reading several books on wood joinery and specifically Longitudinal, Radial, and Tangential expansion rates of different wood species, I found out that this is not possible to stop. "More joints fail from wood movement due to changes in moisture than from abuse or neglect" and that's straight from the book...
Alan and Lianna wrote:I purchased a 120v relay, wired the coil to the power strip and the contacts were put in line to the battery, and moved the charger. Now whenever you unplug the shore power the battery connection to the charger is automatically dropped out by the relay being deenergized.
Alan and Lianna
We installed the new enclosure and decided for our peace of mind to switch to a 200 lumen led lamp that does not put out near as much heat, and more light.
Can you link us to the relay you bought? That's a really nifty idea and isn't hard to use.
Thanks,
-Sean
I like the idea of changing those outside Bargman lights over to LED and would like to do the same. Where did you find your replacement bulb?
_________________
...Sharon....
