skinnedknuckles wrote:Jeremy,
I understand about the height issue for you. You might also think about Brunsell lumber...abbreviated...Anytime that you would want to meet up, let me know, I am in the skinning stages now as my woodworking is pretty much all done.
Have fun making sawdust,
Paul
Mr. Lahey wrote:Hi guys
It's the Delavan builder here. Not only do we live pretty close but looks like we think a lot alike too! Must be something in the water?
I too am going to build my galley cabinets/bulkhead and front headboard cabinet as separate units. I will then slide those in place and attach the walls to them. I'm also going to do a separate roof panel to drop over the top of cabinets. It will be skinned on the inside on the bench before setting in place on the camper.
I really like your new profile. I too am a big guy and have upsized my design to a 10 footer with a larger doors.
noseoil wrote:Not sure about the spar to edge stuff you referenced as I didn't get the book, but it sounds like a simple self-centering doweling jig would be easier to use. I got one at Harbor Freight for my build as the Wellman I had for years is gone or misplaced. (I don't own a kreg jig)
It just clamps the material between two blocks & has an insert to guide the bit into the edge of the wood. I think it cost about 13$ if I remember correctly. It works on different thickness material & gives a centered hole. The marks on mine were off, so I had to re-scribe the center line (cheap POS Chinese tool) for the 3/8" bit.
noseoil wrote:The stove/oven combo is pretty well made. There are no issues with using it or having it run properly. One comment I have heard from people is that the oven will only heat to about 350 degrees, so baking stuff at high temps or a 450 degree pizza oven is pretty much out with this unit. Also, it doesn't heat completely evenly, so turning things is a must with it. Take a look at the build for how I installed the tracks on mine. I've seen drawers & boxes made (wood next to the metal I didn't want), but I just used 2 aluminum angles to support it and it works & tracks very well. Easier to make too.
Make sure to leave enough room for the knobs on your hatch layout, to let it close properly when it swings down to close. Measuring the stove body won't work, if you don't remember that the knobs stick out farther than the actual unit itself. I like your idea for a work surface on top of the stove. A thin bamboo cutting board, cut to fit, would be a good addition to the galley for my build. Thanks for that one.
About the vent & fan, I decided I couldn't make one that would have 10 speeds, self-open & close, have a thermostat & rain sensor & do it all. I'm not that good at electrical things, so it was easier to just bite the bullet & buy one for me.
