bdosborn wrote:Well done! It so nice to have a heater when you're camping, isn't it?
Why choose? Keep the panel on the roof and add the portable panel when needed.lfhoward wrote:Today we got to deploy the auxiliary Renogy 100 watt solar panel on a sunny day and compare to our old 140 watt panel on the roof. The roof panel is capable of 120-130 watts (9-10 amps) at noon on a sunny day, but with shadows from trees and clouds, the best I saw today was around 4-5 amps. The mobile Renogy panel though easily put out 5-6 amps if I put it in a sunny spot and kept it pointed towards the sun.
So, here are some thoughts…
Permanently mounted panel:
- Always charging all day long, although not necessarily optimally
- Relatively safe from “walking away” since it is bolted to the roof
Mobile panel:
- Can potentially bring in more amps if positioned well, even though it is a smaller 100 watt panel
- But it only charges when I have it deployed and am here in camp to keep an eye on it
I see pros and cons for both, and think they complement each other well. I would like to replace the tired 140 watt roof panel with a 200 or 210 watt panel of the same size. For the mobile panel, I would love to have two of them so I can put them together in series for less voltage drop along the wire. I would need newer MPPT charge controllers for both of these options as well. (The 140 watt’s MPPT is maxed out and the Renogy has a PWM controller on it currently.) Looking at Victron Smart 75/15’s.
Users browsing this forum: No registered users and 23 guests
