Oh Yah!
Very popular choice.
IMHO one of the prettiest race cars ever built.
Brian
KCStudly wrote:The arches really tie back into your overall theme, and the pantry should keep everything in place well while underway. Bravo!
noseoil wrote:Michael, nice job on the millwork. It looks like a good design & should give you plenty of storage space. I'm wondering if there will be a top-mounted guide, bracket or tracking "stabilizer" to keep the play out of the unit during travel & when it's being pulled in & out? As tall as it is, there might be a bit of fore & aft play in there somewhere.
OP827 wrote:Michael, that is a fancy design with the slide out pantry, I was not expecting that
Now what is going to be located above the fridge, a wardrobe space?
You are putting a lot of labor and character into this baby, great work my friend.
IndyTom wrote::applause:
Gorgeous work!
Atomic77 wrote:Here's a question for the pro finishers out there. I am spraying most all of the birch with moisture proof lacquer. But I have a couple of areas such as the pantry that I was unable to spray prior to assembly. So I need something quick-drying, brush-able that has a finish that isn't heavy. Thoughts or suggestions?
Sent from my SAMSUNG-SM-N915A using Tapatalk
SCwood wrote:Atomic77 wrote:Here's a question for the pro finishers out there. I am spraying most all of the birch with moisture proof lacquer. But I have a couple of areas such as the pantry that I was unable to spray prior to assembly. So I need something quick-drying, brush-able that has a finish that isn't heavy. Thoughts or suggestions?
I brushed spar urethane on all of my birch and it worked pretty well. In the summer heat it took about an hour to dry between coats, and I applied 3 coats, wet sanding with 400 grit between them. About 6 hours after the last coat it was dry enough to handle however you wanted.
