RIGHT !!!!!
Had a day leave today.
Was up most of the night... coz I am like that.
Had John "GTVSaviour" from Belgium get here at 2am, after he had fetched a Mercedes 5cyl 300D diesel in Essex. By 3am he was asleep, and I was surfing the net, went to bed at 3.45-ish, then up at 04.55am to get him up and away to catch the Channel Tunnel train back to mainland Europe , to deliver the car to Oldbus Dave in Germany , for the engine to go into the Race car transporter Dave's building him.
After that I could not get to sleep, so sat and did company work and month end admin.....
At 7.30am I showered and went to Nicola's place to crawl in behind her back as she was off on leave as well, and her 14 year old son had the day off school.
By 09.15 the guy from the Environmental company who needed a sample of my insulation and ceiling for asbestos analysis called to say he would be here in an hour. So I trekked back here again.
His job took less than 5 minutes.... then I was faced with a dilema: Back to Nicola's and watch telly all day and fiddle with the Ford Anglia, and back here to my place tonight...... OR : Get into the garage, as the rain had cleared, but is was still bloody cold ??
I selected welder, grinder, balaclava and extra thermal protection.
So spent a few hours working out what to do, grinding, welding and comming to the conclusion that I will need to re-seat the floor frame of the caravan , as nothing is now in the same position as when I built it.
Started off with just staring at it all.
Then cut strips off the off-cuts from the welding table I made earlier this year, and ground them into shape to go around the axle, and drilled some holes in plates and chassis .
Next job, grinding the galvanising back, as it is a pig to weld, and quite toxic. (hope I did not get too much of it in) Note the clothing. 2 T-shirts, one Millitary issue Norgy, overall, and a windbreaker topped off with a Balaclava..... NICE !
Bottom section of steel to be a sandwich outside and inside. Also decided to attach a strap upward to stabilise it even more, and to only weld one end , rather than the lot, in case one ever needs to dismantle the whole thing.
Welded the top crack up twice, ground it down, then added a section of strapping over the weld, and welded that down too.... I challenge the weld to break, which does not mean it won't break next to the weld.
Bottom welded, bolted and outside bolted in too.... here's to it all holding out.
The whole structure is now not alligned to the original timber frame I made up, but at least with timber, I can redrill and fix the lot once it is all it's wheels and on the floor.
Lastly, Hammerite, not neat, not tidy, but at least functional.
I suspect I may do tho whole chassis in a single colour once the build is complete.
Tomorrow I think I may be able to sneak out a bit for some varnishing of the sides, and Sunday, Monday of course will be doing London like Tourists.
Have a great weekend !!
Greetings from England.
Rian.
