I would like to share my teardrop build as a way of thanking everyone who's ideas and tips that i have used.
Without this site the build my might not even have started.
I hope some of my pictures or methods help others.
Here goes.
This is my chosen profile(many hours,days,months of pondering)
Floor construction
Using the ply sheet to keep my metal frame square.
Axles going on.
The completed frame.(The drawbar has still to be trimmed to allow adjustments for the load on the hitch)
The floor and frame bolted and sealed.
The base is level.
Sides Cut and mortised.
Cutting the doors
The start of the dry build
Fitting the rafters
The hatch position.
Milling the doors.
The window detail.
The first coat of protection.
Finally getting it together.
The galley.
Fitting the inner skin.
Forming the rear hatch.
Some wiring and insulation.
The outer skin.
Moving day(From my folks house to mine)
Some weather proofing.
Under floor water tank.
Manual tap.
Cutting the plexiglass.
Windows in (temp.)
Galley hinge detail.
Wings.(thanks Ebay)
Here we go.
One of many clamp combinations.
Cutting and fitting the hatch.
Skinning the hatch.
Fitting the trim to all edges.
The only problem is that due to the weather(no surprise there) i've run out of time to get my tear ready for my trip to the isle of Skye.
But at least it's a start.
Thanks for watching.....
Graeme(aka 2fry)
