georgedombeck
All the weight is in the Galley so I dondt know why the designer put the axle that far forward.
It is not uncommon, when travelling, to use the cabin area for storage of, say, an EZ Up canopy, chairs, table, etc... the distance of objects placed from the axle will greatly influence tongue weight.
George, what will you be using as this teardrop's tow vehicle? I cannot recall reading any info about that...
If it's a front-engine, rear-wheel-drive 'Merican car or truck, then tongue weight should be, typically, 10-15% of the trailer weight.
If you plan to use a compact-class, front-wheel-drive car, then shoot for 8% tongue weight.
