by mark6mueller » Wed Jul 06, 2011 11:58 pm
I have used my trailer on several long trips. Got new tires for it on the way to Portland. The old tires were wigging me out. I haven't installed the sway bar yet. The trailer tracks excellently up to about 65 mph. I have gone so fast around corners that the trailer swings out straight behind the car with a medium load. I don't do that often. Gotta test though. At higher speeds, I have to be smooth with the steering so the trailer doesn't oscillate back and forth temporarily. I have been thinking of a sway damper design. This is different than a sway bar. Instead of a spring it would be a linkage and shock absorber that adds additional damping as the trailer leans from side to side. The trailer actually corners fairly flat without the sway bar. This would be to soak up that side to side oscillation energy.
Also I have found that the water leaking at the forward hatch hinge is related to inadequate sealant usage. My recommendation: Don't cut corners. Use RV sealant even though it costs $11 a tube at the local RV shop. The acrylic/silicone 50 year house caulking doesn't cut it.
Best Regards,
Mark.
