Shadow Catcher wrote:RVIA standards for plumbing gas line is black iron pipe back. (I would use galvanized).
madjack wrote:Shadow Catcher wrote:RVIA standards for plumbing gas line is black iron pipe back. (I would use galvanized).
...the reason gas codes call for black iron pipe is galvanized piping can flake galvanizing off and stop up the jets on your gas appliances.....
len19070 wrote:
Very good point Jack.
There is a reason for everything.
Even worse than a stopped up jet is a "Half stopped up Jet" that makes the appliance burn incorrectly...Carbon Monoxide again.
Happy Trails
Len
len19070 wrote:Good morning Gene and welcome.
Mounting an LP Ref in a tear has been discussed here many times and the idea has been abandoned by many people. Not abandoned by me.
In fact I don't know of anyone here or on any other Teardrop board, or in the real world who has a Teardrop Trailer with one in it...I could be wrong. There is always a first.
I'm an Master RV Technician with over 35 years experience and I have tried and abandoned the idea long ago. No comment.
Not that It cannot be done, just that there are to many dangers for me that I'm not willing to take a chance with nor give "How to" advice for. OK with me.
First is the excessive heat that these Ref's put out on any of the 3 sources. 150 watts is not "excessive" and has been sucessfully dealt with or the units would not be in service.
Then there's the open flame in the center of the cabin. I imagine a typical teardrop installation (in a rear facing galley) there will be a solid bulkhead between the reefer and cabin. Not the case in a typical RV where these units are installed safely all the time. Not an issue. My installation will have two solid bulkheads between the reefer and cabin.
The risk of Carbon monoxide. Incomplete combustion can generate CO. So you're gonna have to starve the unit of combustion air (not an issue on a/c or d/c operation), vent the gas directly into the cabin (which is not gonna happen in a teardrop with the unit installed in the galley with a solid bulkhead between the reefer and cabin), and have the gas reach a lethal level. Simply put, not gonna happen.
Venting, very important, If the Ref will have the door facing out in the galley there will have to be a vent at the top and that vent will be at or near the hinge. A great area for leaks. I used to sail in 50 knot winds with green water over the bow. Never had a drop of water get in the dorade vent. Easily dealt with.
With all the requirements that are needed for venting, space becomes an issue. I don't think so. In fact, the less excess space around the cooliing mechanism the better the draft (natural convection cooling) will be and the better the unit will perfrom
And always the risk of an LP leak. So we should give up propane for water heating, space heating, and cooking? Not a valid argument.
Another factor to be concerned with is that the Norcold N323 has all the controls in the back of the Ref, as do many of the small 3 ways. Which means that an access panel must be made directly into the cabin to turn the unit on or off. True but it can be dealt with.
Besides being inconvenient (you may have to remove the mattress to gain access) these controls are directly in the area of the heat and Carbon Monoxide. The unit mentioned above does have the controls in the rear but this issue can be addressed. Most units have the controls right above the door so access is just as easy as getting to the inside of the reefer.
If that access panel...that is in an inconvenient place is not re secured properly you have direct access from the unit to the cabin. Only an issue with the unit mentioned above and for that unit it can be addressed with an airtight door.
As it is you would have an open flame within a few inches of your mattress & you. No more so than a space heater or water heater. The flame/heat source is well surrounded and I "googled" around and could find no incidents to indicate there is a safety issue with these units. If they were that hazardous, given our lawsuit happy society, they wouldn't be on the market.
I would mount the Ref in the galley but make it so it can be pulled when you get to the campground and ran outside the trailer. They don't do this with other installations. Why is a teardrop different?
Your going to get several suggestions on "how to do this" from people who have never done it before. The Wright brother never flew before, before we put a man in space it had never been done before, and I've successfully done a lot of things I've never done before. There is always a first and that doesn't mean it can't be thought out, planned, and safely executed if you get the right input.
I have never done it either, but have tried. Excessive Heat, Carbon Monoxide in the center of the Cabin and there effects were the show stoppers for me. Not the instalation. We disagree on the issues of heat and CO.
Happy Trails
Len
Wikipedia wrote:When not enough oxygen is present for complete combustion, incomplete combustion occurs when propane burns and forms water, carbon monoxide, carbon dioxide, and carbon.
2 C3H8 + 7 O2 → 2 CO2 + 2 CO + 2 C + 8 H2O + heat
Propane + Oxygen → Carbon Dioxide + Carbon Monoxide + Carbon + Water
chorizon wrote:I'm corn-fused....
I was under the impression that the incomplete combustion of any hydrocarbon results in the production of CO as well as H2O...Wikipedia wrote:When not enough oxygen is present for complete combustion, incomplete combustion occurs when propane burns and forms water, carbon monoxide, carbon dioxide, and carbon.
http://en.wikipedia.org/wiki/Propane
eamarquardt wrote:len19070 wrote:Good morning Gene and welcome.
Happy Trails
Len
It can be done effectively and safely. Stay tuned.
Re: how to plumb it. There are always advances being made in materials. What was true yesterday is not always true today. Propane used to be considered too unsafe for use in boats (where it can settle in the bilge and cause a big explosion). It is now very common to use propane for cooking aboard boats. The current standard for plumbing boats is flexible line. If these lines work fine in boats where it is more critical and subject to a very harsh environment (constant exposure to high humidity and salt water), I see no reason thay can't be used for a trailer.
http://www.boatus.com/boattech/casey/18.htm
http://www.tridentmarine.com/stage/lpg_hose_fitting.htm
http://www.fireboy-xintex.com/propane_d ... html#Hoses
Gus
