Another Build (Update 10/03/2011 Finally finished!)
Postby Steve Frederick » Sun Jul 25, 2010 9:04 pm
I'm a bit bored. I haven't been building for a while. I have a frame for a 5 by 8 made for a project that the client bailed on. So..I'll be building a 5 by version of the trailer that I designed for peg.
The details are up in the air for now. I'll be selling it when done. If I get a buyer soon, I'll complete it per their specs. Otherwise, I'll just putter along as I can.
I got the floor done today, and will start the walls later this week.
Last edited by Steve Frederick on Mon Oct 03, 2011 1:53 pm, edited 7 times in total.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby prohandyman » Mon Jul 26, 2010 5:18 am
Great to hear from you Steve. Will follow along with this one as usual.
Dan
prohandyman
Images: 785
Postby Steve Frederick » Fri Aug 06, 2010 10:38 am
I'm thinking about using a manufactured door for this project. I was looking at one on line, but lost the link.
Anyone got a link to a supplier?
I'm thinking of one that has an operable window, frame and lock.
TIA..
Progress;
Nothing new to report. The floor is done. I need a break in the social/camping schedule, to get back in the shop.
I'm working out a new wall joinery/assembly method. More as I get it worked out.
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Miriam C. » Fri Aug 06, 2010 11:07 am
:shock: The things I miss :? Looking forward to the pictures! :twisted: Now where did I put my money tree! :oops:
Postby S. Heisley » Fri Aug 06, 2010 5:28 pm
If you're doing it, Steve, it'll be worth waiting for. :thumbsup:
Postby doug hodder » Fri Aug 20, 2010 11:56 pm
Sorry Steve...somehow I missed this...make sure you keep us all posted on the progress OK? Doug
Postby 2bits » Sat Aug 21, 2010 12:58 am
Check in with caseydog, he has a manufactured door although sleasebay is always there too. Enjoy the new build puttering is the only way to go!
Thomas
2bits
2bit Member
Postby bve » Sat Aug 21, 2010 9:15 am
I'll be watching closely too. Why the decision to try the manufactured doors?
Here is a link to the same doors on e-bay.
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
Postby Steve Frederick » Sun Aug 22, 2010 4:44 pm
Well, some progress on the build.
I got side panel sections cut out, ready to assemble into panels.
I have the floor ready to go.
I've changed my mind about a manufactured door. It seems kind of silly to build an interesting side wall, only to cut most of the interesting part out for a door.
I'll be using my traditional method for the door (doors?)
I shot a couple of pics. I'll upload later this evening.
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Steve Frederick » Sat Aug 28, 2010 1:57 pm
I finally downloaded some pics from the shop.
For most viewers, nothing new so far. Well, anyway...
Floor, 5-by-8, 3/4 foam, 1/4 ply bottom, 2-1/4 ply layers on top...
Blocking for bolts...
High tech clamping system! All plywood is glued with PL adhesive, and stapled to the frame, then "clamped"...
Finished floor. I'll trim the ends to match the profile later..
Here is the back of the wall ply.
Street side, ready for glue-up..
Here are both sides, and the floor. I cleaned up a bit since the first shot!..
Street-side again, glued up and 'glassed...
To glue the side sections together, I worked epoxy into the seams, covered in waxed paper, then "clamped" with weight..A poor-mans vacuum table!
Gluing the seams first, then finishing doesn't seem to have an effect on finish color. The wood is Oak and Cherry...
I have both sides ready to cut to profile. I'll give them a week to cure before I do that.
Next..Wall framing!
My shop/camping buddy, Cooper, is shot!!
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby S. Heisley » Sat Aug 28, 2010 5:48 pm
Interesting....I look forward to seeing how the trailer walls will be cut and worked around that wood design. :applause:
Cooper is a pretty dog!
Postby Steve Frederick » Mon Sep 06, 2010 5:42 pm
I had to use some vacation time, so I spent a couple of days on the walls;
I reinforced the back of the wall panel parts;
Prepared to cut the wall panels to my pattern;
Wall panel, ready to go;
Wall framing roughed out;
I used biscuits for the joints;
I built the second frame on top of the first, separating the two with waxed paper.
Galley layout..for now;
I glued up the frame/wall. This is the street side;
Curb side, all glued up;
I'll cut the door/doors (can't decide) out after the whole assembly is laminated..
Coop worked very hard this weekend!
Thanks for looking!
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Nathan N » Mon Sep 06, 2010 6:25 pm
Beautiful! :thumbsup:
Nathan N
Images: 153
Postby Sparksalot » Mon Sep 06, 2010 7:15 pm
Gravity clamps! I'm not the only one. 8)
Sparksalot
Images: 682
Postby Steve Frederick » Mon Sep 06, 2010 8:55 pm
Sparksalot wrote:Gravity clamps! I'm not the only one. 8)
Gravity...It's the law!! :lol: :lol:
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Users browsing this forum: Google [Bot] and 7 guests
