Didn't want to hijack the "cardboard teardrop" string but wanted to say some things about FRP or "fiberglass".
First, there are different types of resins and each has advantages and disadvantages. End of discussion on this point.
I've never done a "big project" myself but I've witnessed a friend build two commercial fishing boats. It's really impressive what you can do with a bit of fiberglass (mat, roving, and cloth), some foam, and some resin.
I've repaired carboard glove boxes for cars, a small patio fountain bowl that got broken, plastic fenders for ATVs, and also reinforced a motorcycle fender from the underside with several layers of cloth so I could mount a taillight and license plate on a fender that otherwise would be too flimsy to support the additional weight.
In addition I've repaired swimming pool diving boards, made guards for machine tools, and lots of other little projects repairs.
Nothing sticks to ATV/Motorcycle plastic very well but you can still effect some repairs by backing/holding the damaged piece together with some duct tape and then applying glass/resin to the back side and then pop riviting the plastic and FRG together after the resin cures. Not as pretty as new fender but these repairs seem to hold up pretty well. Cheaper than new plastic if it's even available (a lot of the stuff I work on is not exactly brand new).
I'd be interested in some "outside the box" uses for FRG that other have used.
Never too old to learn.
Gus
