My foam top is almost fully assembled. I still have sanding and patching to do and to insert the four small pieces of wood into the sides for the latch catches to attach to and install the fan, light and wiring. I decided to use foam instead of wood for my panel spacers in the upper corners of the top where it joins the sides, front and back.
I couldn’t wait to see what it weighs. I gathered up an extra piece of foam and the wood pieces to add to the top’s current weight. With all of these plus the top, without the fan and light, it didn’t quite weigh 10 lbs. I think it was 9.8 or 9.9 lbs difference between my weight on the scale with and without me holding the top and parts. The vent/fan weighs 11 lbs according to their WEB site. Finished, the entire top should weigh only 22 lbs.
That’s 10 lbs. below my original estimate and very little more than a quarter of the wood top's weight.
Why, why, why didn't I think of using foam in the beginning and save my back a lot of pain lifting that heavy one on and off the roof?
Lifting it won’t be the problem anymore. Keeping it from blowing off the roof when it’s unlatched may be…lol. I certainly won’t have any problems getting this top onto the roof by myself. I just hope I don’t run into any hail storms. That’s the only worry I’d have with the foam top as I didn't put any epoxy on it.
I may consider the cloth and epoxy treatment before I finish it. Adding another 10 lbs is not a problem now that I know how light it is. I have just enough 2 oz. fiberglass cloth to cover it and two full quart bottles of 2-part bar epoxy that I've used to cover wood objects with, such as my step for the Squidget. It is slow setting up, taking several hours to harden, so I think it would work fine for this job. I'll make a small test with it before I put it on the top. With the high heat and low humidity we are having, the epoxy should cure faster.
