Ok, so here is the review:
Lite the 3 candles first, let them heat the top plate for a half hour or so.
Then turn on the fan and it will blow all that heat around the TD.
Does a good job, you can feel the heat coming off it quite well. The fan is very quiet, but does move air.
Now the problems; the candles are not dripless. The front candle can drip wax out side of the holder. I will be making a small tray to catch any stray wax. I seem to have discovered cowl induction; the fan blowing from the back swirls over the front edge and cuts down on the effectiveness of the candles. It makes the flames dance and swirl. Any Ideas on how to fix this? I have a feeling that if I put the grill on the front all the way to the top of the mini (my original plan) that the fan will blow the candles out, so I will only go as high as the 1/2" plate. But how will I fix the "cowl induction"?
There is nothing that I can build that I cannot unbuild. <or> Mistakes will be made, action will be taken.
