floor
floor
Postby Boanerges4 » Mon May 23, 2011 9:57 pm
Got the frame completely back together. Its an 11 ft by 6 ft 4 inch popup trailer. I removed all surface rust and put 10 cans of rustoleum shake and shoot back on. I also checked bearings and re-packed them. I also put new 10 inch tires back on, waiting flor hubcaps to be shipped. Im very pleased so far.. I began to play around with floor today, and by the way it will be a 6ft 2 inch tall STANDY, should I use 3/4 flooring and brace on the seams or should I go with 1x4 structure with 1/2 plywood on top? I think you can daydream all day because theres a hundred ways to build these things. I built my own home so Im not completely new to this. Im trying like everyone else to go as light as possible. My exterior walls will be 1/2 plywood with 1x4 sub wall. the outside wall will also be the inside wall except for exposed 1x4. Any help appreciated, thanks :D
Boanerges4
