OK, here we go
I've posted in the Newbies section, so Hi all
I'm building a teardrop (really?) and this is my build diary
Started with google sketchup and got this.
Teardrop CAD by RoadkillUK, on Flickr
I then went to the builders merchants and got this.
Flat Pack by RoadkillUK, on Flickr
On the CAD drawing I put a grid of 100x100mm over the top and printed that out, then drawing a 100x100mm grid on the 8'x4' I transferred the outline by hand, cut out using a jigsaw (I need a new jigsaw). The next step was to glue and staple 75x25mm to the outline of the new wall.
Gluing the sides down by RoadkillUK, on Flickr
This is about the size of it by RoadkillUK, on Flickr
Yesterday I put the base on the trailer and then put the sides up (all temporarily) so I could measure for the bulkhead. Bulkhead now mostly built.
Is it done yet by RoadkillUK, on Flickr
Bedroom by RoadkillUK, on Flickr
Also if you look you can see that I have cut and routed the ribs for the hatch.
Today I am trying to locate some 20mm insulation, if I manage that I'll get the 2 sided fully built and also finish the bulkhead.
