StandUpGuy wrote:If you are looking for a name for it the "Cube" is available I believe.
vanwyk4257 wrote:Thanks for the input. The frame was a big part of the reason I bought this camper, it's build like a sherman tank. Once I get another 4wd, if Jeep ever sells the diesel JK Unlimited here in the states this thing will get towed all over off road so I might need to think a bit more about CG. I'll have to do some thinking about it.
I would like to see some elevations of what you are planing for this trailer. You have already started building. If I throw a shape onto your original trailer photo with the front swept back slightly I get this:vanwyk4257 wrote:My current thinking is to go up 42" on the front wall vertical and then lay the wall back on an angle that brings it back about 24" at the top.
I might look into doing a popup like your avatar too ala' VW westfalia but then I'd have to engineer more stuff. I'm sure it's going to have a lot of wind resistance even with the angle on the top but I'll seldom venture further than 2-3 hours from home with this trailer. Who knows, I may really get the bug and build a TD next.
Users browsing this forum: No registered users and 27 guests
