Saturday: (Aug. 18, 2012)Trailer Modifications:Worked a little on the frame. We got some angle welded to the sides of the tongue and under the frame. There is a huge difference in the amount of "play" and twist in the frame now. (pics to follow soon.)
There were several pieces of angle attached to the sides of the trailer frame that I assume were to be used for side boards on the trailer. I cut those off and ground them down pretty smooth.
The fenders were a "female dog" to get off. I finally got them removed but it left behind a lot of metal. I ground on the leftovers for awhile. Finally I decided to just leave it. When I dry fit my walls to the outside of the frame, I'll mark the wood at these spots, and then I'll use my router to remove just enough wood to allow the walls to lay flat against the frame.
I removed the tail lights/turn signals along with the metal brackets that held them in place.
Sometime this week my Brother-In-Law is supposed to add some angle supports down the middle of the floor between the cross members. Afterwards I'll touch up the paint and bring it home.
EDIT (8-25-12) Here are before and after pics of the trailer.
Before:
After:
- trailer after modification
- IMAG0038.JPG (228.19 KiB) Viewed 990 times
I also did some scavenging for parts yesterday. I have an old camper that needs to go to the scrap yard. I was able to salvage a roof vent and two door handles that I believe I can make work on the teardrop.
Sunday: (Aug. 19, 2012)No work today...I had planed on making my template for the walls today,then cutting, sanding, and putting on the first coat of primer. However, it's raining here today and I don't have a shop/garage to work inside. Even if it stops soon, it's still so damp outside that I wouldn't feel comfortable working with "naked" wood out side today.
Maybe I'll get off work early enough this week to at least draw my pattern for my template.
Mitch
