Cross Bow / trolley / renamed little blue trolley
Postby Ron Dickey » Sun Jan 13, 2013 12:32 pm
viewtopic.php?f=21&t=49872
up Date 3-3-2013 I am building the Cross Bow and gave my self 60 days for the 20th Dam Gathering or in my case the Damn Run.... :?
Up Date .3-3-2013 .. I talk about many of my dreams below but not until page 2 do I get started. and my design has gotten pretty basic when you are in a hurry.
I am thinking of building a new trailer, thought my wife tells me I have not finished the BoxKite. On the Box Kite it was the doors that stopped me now it it the trailer frame. The Box Kite frame was an old boat trailer frame and has a fixed axel I can not move. So it took me 4 years to build the last one and now that I know how to build one it could take as little as a week to build but it will take me years to design.
The above thread is the start of what I want to do and I call it the Cross Bow because I want the curve to go left to right not up and down. I do not have a true galley in the Box Kite and there fore when driving down the road and stopping we can just open the back and get a snack. The Box Kite can be used as a Utility Trailer and a camper, The Cross Bow will be a purely camping trailer. Because it costs so little to insure and license a trailer it makes sense to have several. How ever I do have a friend who has 8 and his wife is about to kill him, one of which is a TTT.
In here I will place my research so I can catch up if I forget, you do that as you get older and our town is about to put in an $18,000,000 sewer so my funds will suffer soon, which means I may have to use spare change to buy the parts. :NC
The Rain Drop starting my thinking in this direction
http://www.youtube.com/watch?v=m0P9mp6FhBI
http://www.youtube.com/watch?v=Wihla9Vml80
also manufactured with a bow front is the Airstream Base Camp
http://www.youtube.com/watch?v=mZUA1TnhMU4
I have a drawing I will try and find and pull up too.
Ron Dickey
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 707
Re: Cross Bow
Postby Ron Dickey » Sun Jan 13, 2013 7:58 pm
Here are some more examples
This is a pointed teardrop from southern California other shots are on my Gallery.
101270
offers a side galley
Ron Dickey
Images: 707
Re: Cross Bow
Postby Ron Dickey » Sun Jan 13, 2013 8:24 pm
101280
I am not the first to try this someones build above
Raindrop body before assembly from Camp Inn all made from hand.
101279
Ron Dickey
Images: 707
Re: Cross Bow
Postby Ron Dickey » Sun Jan 13, 2013 9:51 pm
The Galley I want should look something like these guys
you tube pull out tables.
http://www.youtube.com/watch?v=NT5whNoQ3b8
Ron Dickey
Images: 707
Re: Cross Bow
Postby mezmo » Mon Jan 14, 2013 12:45 am
Hi Ron,
Don't forget Irmo Atomic's Torpedo build, inspired by an early
1930s Airstream [pre-aircraft style]. Pretty much what you seem to
be aiming for.
http://tnttt.com/viewtopic.php?f=50&t=51954
Norm/mezmo
mezmo
Images: 194
Re: Cross Bow
Postby Junkboy999 » Mon Jan 14, 2013 2:50 am
This my favorite curved front TD build. I know it’s has been posted somewhere before. But.. here it is again.
http://www.youtube.com/watch?feature=en ... 6telY&NR=1
Junkboy999
Images: 52
Re: Cross Bow
Postby RandyG » Wed Jan 16, 2013 5:20 pm
This is the same design I'm aiming for (I like the name crossbow, never heard it called that).
This clip shows some of the 560 under construction, http://www.youtube.com/watch?v=iYzT3p008KE
I was never able to find pics of it being built so this is the closest I found for reference from Camp Inn.
Randy
RandyG
Images: 115
Re: Cross Bow
Postby Ron Dickey » Wed Jan 16, 2013 10:04 pm
Junkboy999 wrote:This my favorite curved front TD build. I know it’s has been posted somewhere before. But.. here it is again.
thanks that is amazing I am not thinking of doing a standy but it is tempting.
I wonder how they got the boards the bent steamed?
Ron
Ron Dickey
Images: 707
Re: Cross Bow
Postby Junkboy999 » Thu Jan 17, 2013 12:18 am
Have you seen finleycraft Build thread, The Finley T1, It is nice and wide with a bow front as well.
viewtopic.php?f=50&t=51053
And the CAD picture I posted above would of had windows in the front. It is just easier to model the body
and add windows later, and I have no idea where to buy curved windows if I did build it.
Bending wood
Most people get really thin plywood design to bend. ( some time called Barrel plywood ) All the fiber of
the layers run in the same direction. Steaming will work but hard to steam a full sheet + steaming plywood
can melt the glue. Keeping one side dry and heated while soaking the other side with ammonia and water
helps the bending as well. Dryer side shrinks wet side swells.
I bend steam wood ( not play ) all the time for my RC planes and woodworking hobbies.
Junkboy999
Images: 52
Re: Cross Bow
Postby Ron Dickey » Fri Jan 18, 2013 11:39 pm
as I research this Idea it is nice to know I am not the first
viewtopic.php?f=27&t=51357
They get into it here and have some side layout diagrams too.
Ron
Ron Dickey
Images: 707
Re: Cross Bow
Postby Ron Dickey » Wed Jan 23, 2013 11:58 am
I am thinking of instead of bending the wood which looks cool I could cut out an arch in the plywood floor and top and cut out inserts for each of the pieces of wood that would go up. That way the wood would have more strength.
I know I will have to draw my idea and post it. so it make more sense.
looking like half a diameter of this picture.
it would look a little like this horizontal wind mill before the sheet of oak gets glued on.
I am thinking of cutting it out of a second piece of arched with gear look of wood and gluing that to the top and bottom pieces for two reasons
1. I will have smooth surfaces for both top and bottom.
2. the inserted wood bars would be attached on sides and ends.
Ron Dickey
Images: 707
Re: Cross Bow
Postby Ron Dickey » Wed Jan 23, 2013 12:00 pm
Hmm :thinking: wonder what the inside could look like well I am not this skilled but it sure looks nice.
Dream on!!!!
Ron Dickey
Images: 707
Re: Cross Bow
Postby RandyG » Wed Jan 23, 2013 4:24 pm
I too, have been thinking of how to curve the front. I pondered on the idea of cutting strips instead of bending the wood but I'm still on the fence. What is the radius of the front going to be on your trailer? Mine will be 12".
Randy
RandyG
Images: 115
Re: Cross Bow
Postby Ron Dickey » Wed Jan 23, 2013 10:44 pm
I am thinking of somewhere between a 15 degree and 20 degree angle I have know idea who long that is but it will be 4 feet wide.
Ron Dickey
Images: 707
Re: Cross Bow
Postby Ron Dickey » Wed Jan 23, 2013 10:53 pm
lines to side showed size they are in 5 Degree units.
Beat angle is red, the green angle is 15 and 20 is purple. the light blue is 35 degrees.
I am also thinking of putting a box one the front much like the one on my old one but it's back will equal the same as the arch. I could go up to 25 but no box on front.
Ron Dickey
Images: 707
