Building the "Heart of Gold" - Done 3/9/2014
Re: Building the "Heart of Gold" - Done 3/9/2014
Postby RAB64 » Sun Sep 28, 2014 9:20 pm
Thanks for the feed back. That's what I used today as well, and went on like paint. By the way I really like your build, great job!
RAB64
Postby drewh1 » Mon Sep 29, 2014 11:21 am
Thanks!
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Re: Need a little help Please!
Postby ukewarrior » Fri May 08, 2015 9:15 pm
Can you provide a link/source for the black units shown below that you use to close your hatch?
I like them better than the metal draw hasps.
Thanks for sharing this build.
aggie79 wrote:
In hindsight, I ended up placing a piece of flat aluminum on the hatch to cover the gap. The aluminum projects beyond the edge of the hatch. I probably would have been okay just placing a seal on it rather than using the double P-seals. I don't have a good picture of the flat other than this one that shows the hatch closed and the rubber latches that I use to keep it closed while in transit.
Take care,
ukewarrior
Postby drewh1 » Mon May 11, 2015 11:06 am
Hey ukwarrior - that photo isn't my teardrop - augie99.
Check out the fish I speared up on the coast this weekend. 8)
drewh1
Images: 7
Postby KCStudly » Mon May 11, 2015 5:54 pm
IIRC Tom (aggie79) got his draw latches from McMaster-Carr; perhaps these.
Postby drewh1 » Sat Aug 20, 2016 2:35 pm
wow, it has been awhile since my last post. Guess I have been having too much fun.
I have a set of the original Harbor Freight 12" wheels and tires - Free for anyone who wants them in the SF Bay area.
drew.
drewh1
Images: 7
Postby retep » Sun Aug 21, 2016 8:45 am
Drew. Thanks for sharing your build with us. Your build is very inspiring. Thanks again, and you have a great TD. Very very well done.
retep
Postby drewh1 » Mon Aug 22, 2016 2:39 pm
Thank you! My pleasure, I couldn't have done it without learning from all the other build journals!
drew.
drewh1
Images: 7
Postby drewh1 » Wed Oct 05, 2016 4:59 pm
Just back from a two week trip around Oregon: Crater Lake, Smith Rock Climbing, Hood River, Coast with a final night at Jackson Wellsprings in Ashland. Great trip, tear drop and Fj performed flawlessly! I just added the small propane tank and mounting along with a new Partner Steel Stove. Really helped to have more propane for the trip.
drewh1
Images: 7
Postby drewh1 » Mon Oct 23, 2017 12:46 pm
IMG_4350 lr.jpg (63.44 KiB) Viewed 3095 times
IMG_4106 lr.jpg (76.29 KiB) Viewed 3095 times
This years trip was through Nevada and Utah, to Moab. We drove back almost the entire way on dirt roads and did a lot of off-road primitive camping. Had some trouble with the hitch and trailer bottoming out. So I am going to change out my suspension. Going with Timbren 2000# with 4" lift. Will also install a cross-member. I'll post pictures when I get the parts and get started.
drewh1
Images: 7
Re: Building the "Heart of Gold" - Upgrading to off-road Sus
Postby drewh1 » Sun Nov 26, 2017 12:10 pm
I am replacing my stock suspension with Trimbren HD 2000. I went with the 4" lift version to get some higher off-road clearance. Removed the old axle and springs. The hardest part so far was cutting away the overlapping wood and aluminum from the frame. Both sides are mounted, now I need to add a cross member. The HF trailer has a cross member, but I want it to be extra supported.
drewh1
Images: 7
Postby drewh1 » Sun Dec 03, 2017 5:28 pm
Came out well, 18" of clearance with the 14" wheels. I was able to center the wheels in the fenders better. I can get a couple more inches with bigger tires and wheels but for now, i'll live with it.
drewh1
Images: 7
Postby bdosborn » Sun Dec 03, 2017 8:04 pm
Hows the new axle ride, have you taken it out yet?
Images: 772
Postby drewh1 » Mon Dec 18, 2017 9:59 pm
Hey Bruce - nice to hear from you. we were in Cozumel diving for a couple of weeks. I have only taken the TD around the block with the new suspension, so I don't have much experience with it yet. We will likely do our annual New Years eve camping trip so I'll have some better feed back then.
Have a great holiday!
drewh1
Images: 7
Postby bdosborn » Thu Dec 21, 2017 8:56 pm
Images: 772
