EVOLUTION of construction design/plans for the floor and walls to support a large truck cap for a TTT:After speaking to a guy at home depot who seemed to grasp carpentry...he suggested that the flex of any Two-by/2x___ wood (x2, x4, x6) will flex the same if layed down flat orientation when bolted to the trailer as the subfloor beneath the 1/2" plywood I have as a floor. So, a 2x4 will be just as good as a 2x6 UNLESS you orient them taller than wider.
I will not be doing this as it will yield too much overall height. SO, I am going to have 8 of these 2x_?_ members bolted to the trailer...since they will be flat I will go either 2x
3 or 2x
4..not much of a weight difference overall.... I COULD sacrifice ONE ADDITIONAL INCH by orienting 2x3's upright .vs. 2x4's on their sides if it would really make the flex on the floor THAT MUCH BETTER?????
I will then have to build something similar to typical American home 2x4 wall construction with all 3 boards being the same type of size: A bottom "base-plate" run horizontally, a stud vertically oriented (
2 options on this) and a top-rail.
I'm not sure if I will use 2x3's or 2x4's for this...I'd like to orient the studs as they are supposed to be...but this puts their longer dimension going INto the middle of the trailer and eating up inner-camper width/space. I may go with 2x4 basePlate and topRail and 2x3 studs.. or just all homogeneous sizing......
ANY SUGGESTIONS ABOUT THIS????....
....considering the wall will be reinforced by an outside skin of plywood as well as some L-brackets and the back "wall" will not have studs but be a kind of "U" shaped laminate of plywood to allow for the truck-cap to have something to come down and connect with (see the image I'll insert below of how OHBUGGER did his back wall:
WALL STUD SPACING: I have options: do I stick with 16"-on-center or can I go wider and maybe save the weight of a few 2x4's? if so, how much wider? OR, is it even worth saving the weight considering the wall will only be 22" tall..so every 4 studs would be really from just one board and since 2x4's weigh about 12lbs each...and I have a 22 horizontal feet of walls to build (2 sides and one front)...16" on center would mean a total of 264" of wall length and if 16" on center, then 17 studs can come from ~4 boards....going to 20" or so "on-center" would only drop the number of 2x__ boards down to 3.5...even at only 3 boards....it is only a savings of 12lbs if I used 2x
4's.
ALL THIS WONDERING AND 2ND-GUESSING IS ANNOYING!!!!
But the rain is either stopping or gone for a while...I"ll go take some pics
of the cap as I promised 2 days ago.
More to come...Thanks!!!!!!!!!!!!!!!!!!!1
_John
