"The X-Cubed" C.T.T.
Re: "The X-Cubed" C.T.T.
Postby Sparksalot » Fri Feb 09, 2018 2:47 pm
This million year old pic shows the VIN plate location on my frame. Right there on the tongue. That's the only reason I haven't changed it yet.
34362
Done? Surely you jest. A teardrop is never "done".
It's got a cop motor, it's got cop tires, cop suspensions, cop shocks.
Sparksalot
Images: 535
Postby working on it » Sat Feb 10, 2018 2:27 pm
Sparksalot wrote:This million year old pic shows the VIN plate location on my frame. Right there on the tongue. That's the only reason I haven't changed it yet.
34362
  • I wouldn't have changed mine either, but it was damaged and unreadable. When I replaced the original damaged single-beam tongue, with a much thicker and longer piece of square tubing, I just threw it away. I showed a picture, saved on my phone, of the disposed of VIN label, and a previous license plate sticker (from many years prior) to the Tax office clerk, and re-registered without problems.
  • 86925 old tongue (with VIN label), both damaged and disposable!
  • 86928 new tongue, without VIN label, but OK with the State
  • If I ever go to Harbor Freight again, I might pick up a set of their number/letter stamping dies, just to make it "identifiable", as if its' unique self, is not. Just for the sake of the govt. sanctions for ownership.
    HF number & letter stamping set.JPG (69.19 KiB) Viewed 586 times
2013 HHRv "squareback/squaredrop", semi-offroad, 4x8 TTT, 2150 lbs
  • *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, & active-progressive bumpstop suspension
  • *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system modified for single-beam tongue
  • *100% LED's, GFCI outlets, 3x fans, AM/FM/C *A/C & heat, Optima AGM, inverter & charger(s)
  • *zinc/stainless front & side racks *98"L x 6" rooftop rod & reel carrier tube
156215157958148599
working on it
Images: 455
Postby absolutsnwbrdr » Mon Feb 12, 2018 6:49 am
34362
Oooh that must be an older Northern Tool Folding Trailer kit? I think they have just a solid center member now.
Zach
absolutsnwbrdr
Images: 410
Postby absolutsnwbrdr » Sun Mar 03, 2019 3:29 pm
At 5 years old, the X-Cubed just made the cover of CoolTears Magazine! :D
https://www.cooltears.com/blog/cool-tears-march-2019
Zach
absolutsnwbrdr
Images: 410
Postby lfhoward » Sun Mar 03, 2019 10:13 pm
absolutsnwbrdr wrote:At 5 years old, the X-Cubed just made the cover of CoolTears Magazine! :D
Congratulations!! That’s really cool to have your handiwork spotlighted on the cover of a teardrops magazine. :applause:
lfhoward
Postby absolutsnwbrdr » Thu Mar 07, 2019 8:59 am
Thank you! Yes, very neat! :D
Zach
absolutsnwbrdr
Images: 410
