Benroy style dutchie (campable)
Re: Benroy style dutchie (galley)
Postby teddy » Mon Apr 06, 2015 12:55 pm
I made me a tablerouter last week, so i could make some trimpieces (isn't moulding the right word?)
Cut them to size in my small homebuild miterbox
And with some CPES it should make a waterproof box of the top shelf. So if the hinge leaks, it's not going anywhere.
As of today, im working on the hatch! got the mockup beam fitted, needs a little trimming here and there to fit the spars, but all in all, im happy with it. I just got a bit of a scare when i noticed the size when opened :D On top are the interior trimpieces, i ran out of spraylaquer, and im not paying 3x the price to get them today, so it has to wait till ive got some time this week to drive to my regular shop (Action, some sort of dollar store i think)
teddy
Images: 187
Postby dales133 » Mon Apr 06, 2015 10:44 pm
Looks great , looking forward to the hatch build
dales133
Postby teddy » Sun Apr 12, 2015 2:42 pm
dales133 wrote:Looks great , looking forward to the hatch build
Your wish is my command!
First i made a template out of a piece of MDF left over from my side template. (sawing, sanding, adding pieces, more sanding)
Then i took a 4x8 board of 3/4" plywood, cut it to workable sizes, ripped the sqare pieces, and i copied the template a few times on the leftover board.
Roughly saw them out,
remount the template, and run them on the routertable, fitted with a flush trim bit.
And voilla, multiplication!
And this should make a hatch.
first a fitting,
then rebuilding with glue.
And it fits!
I still need to add a few more pieces between the ribs, but my back was killing me, and i decided to postpone that to later this week.
teddy
Images: 187
Re: Benroy style dutchie (hatch)
Postby teddy » Sun May 03, 2015 11:26 am
Very busy lately, so not much progress, but this weekend i had some time to cross some things off my list.
Wired the reading lights, added a dimmer and a few buttons, connected the fan wires, trew in a USB charger, connected the cabinetlight. Anyway, eureka!
teddy
Images: 187
Re: Benroy style dutchie (interior lights)
Postby SteveE » Sun May 03, 2015 9:22 pm
I love your build and downloaded the PDF profile you had in an earlier post.
Do you have the radius dimensions you used?
SteveE
Re: Benroy style dutchie (Ceiling in the works)
Postby ukewarrior » Mon May 04, 2015 12:49 am
teddy wrote:Today i mounted the walls, lots of sealant between it and the floor (yes, its mounted on the floor in stead of against it).
How did you mount your walls? I don't see an inside cleat. Pocket screws from the interior framing, from underneath?
ukewarrior
Postby teddy » Mon May 04, 2015 2:14 am
SteveE wrote:Do you have the radius dimensions you used?
I'm sorry Steve, i dont have those dimensions, i just drew lines till i liked them, there's no calculated method to them. Only the top of the doors are perfectly round.
ukewarrior wrote:How did you mount your walls? I don't see an inside cleat. Pocket screws from the interior framing, from underneath?
From underneath, i drilled holes an countersunk them, coated them with CPES and screwed straight trough the floor.
teddy
Images: 187
Postby teddy » Mon May 04, 2015 1:47 pm
Small update, finished the electrics.
The cabinet where all the mains comes in, gets distributed and converted to 12V.
All the wires are routed behind the wooden trim.
Trough a channel in the insulation,
and end up in the headboard. Note the lights turned down low.
The hatch is getting a CPES treatment aswel.
And my homemade sink fits! Its just a 1/2 size gastronorm tub with a drain added.
teddy
Images: 187
Postby teddy » Mon May 18, 2015 3:08 am
Time is still scarce, but ive got some things done.
I've finished the drawer for the fridge,
fitted it.
Dropped the fridge in.
And behold, it works!
teddy
Images: 187
Postby dales133 » Mon May 18, 2015 3:12 am
Nice work teddy looks tidy
dales133
Postby KCStudly » Mon May 18, 2015 2:40 pm
Very nice work. :thumbsup:
Images: 8116
Postby teddy » Thu May 21, 2015 5:28 am
Ive added a pdf file containing the profile on a 1" grid to the startpost of this tread, might be usefull to someone. or get it here.
teddy
Images: 187
Postby teddy » Sun May 31, 2015 2:35 pm
Summer's around the corner, i'm getting antsy to go camping!
Lets start with an image of the kitchen, as it looks almost finished.
Well, finished, campable is more accurate, as im moving more and more things from my "todo" list to my next year list!
The mains is in the works,
All it needs is a breaker and an external connector, and making everything untouchable.
Four wall sockets in the interior,
and a connectionbox for the fridge.
This morning i went to the local camping store, and picked up the hardware for the waterworks, drilled a hole trough the floor for the waste water,
Connected my newly aquired tap, and it works,
Its just a closed sytem for the moment, just to test for leaks, and ive found none, im a bit shocked!
teddy
Images: 187
Re: Benroy style dutchie (doors and Wiley windows)
Postby teddy » Tue Jul 14, 2015 4:42 am
I've received a shipment of aluminium T and L profiles, yay!
Softenend parts of it. The flame changes from blue to yellow when at the right temperature.
It fits! not perfect, it needs some convincing with a hammer later on, but all in all, im happy with it.
The hatch didn't fit too well anymore, it was a bit too snug to open smooth, so i had to narrow it a little ( 6mm, about 1/4"). It wasn't too bad to take apart, exept for the glue, epoxy, and screws i epoxied over. (heating up a screwdriver did work quite well to get the epoxy out of the heads, and loosen the screws.)
Anyway, the doors. a template,
sawing and copying .
Glueing the liner on.
Wiley Window on the bench.
Both windows mounted.
And pic of the entire door.
teddy
Images: 187
Postby flbikejunkie » Mon Jul 27, 2015 5:55 am
Looks great! Should be camping soon.
flbikejunkie
Images: 134
