The Astroliner
Re: The Astroliner
Postby bdosborn » Thu Jan 31, 2019 5:17 pm
Atomic77 wrote:What's your cubic ft? Ours is around 700
About 400 and I've got 1-3/4" of polyiso insulation everywhere. I also have small CPU fans that blow the hot air from the ceiling down to the floor so it doesn't stratify. But didn't you say an electric heater kept you warm? Those are usually 1.5kW.
Images: 506
Re: The Astroliner
Postby Atomic77 » Thu Jan 31, 2019 5:39 pm
About 400...
As I look at these heaters, I see the 5kw is only 5 on high. Low is 2kw. I agree that 2kw is probably good. But then if it's not, then what? And I won't sleep without a vent or window cracked, so I suppose if 5 is too much I can always open the Fantastic Fan. If there was a price difference that would be my tipping point. But there's little to no difference in price. You're also right about the electric heater keeping it pretty comfortable. Although I will use the Flame King to bring it up to temp a lot quicker and supplement once in a bit after I've had the windows cracked.
I never overthink anything. Still on the fence...
Sent from my SM-N950U using Tapatalk
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Thu Jan 31, 2019 5:46 pm
Projector wrote:Just popped in to say that I love, love, love what you have created here. Amazed at the time, dedication, planning, creativity, ingenuity and resources put into your build.
Love the Astroliner design and theme, retro kewl!
Rad, awesome and unique, to say the least.
Win, win, win!
You know, you need a couple muscle bicycles on a back rack, a couple Schwinn Stringrays or Sears Screamers come to mind, complete with stick shift and slicks.
In the back of my mind, someday, would like to build a retro rocket, early 60s, futura styled cruiser motorcycle complete with late 50s Cadillac rear fin and rocket
turn/ taillights. Jetsons style.
All in the same style, era as yours.
I dream of genie.... Yup, definitely got to have a genie in a bottle, with Barbara Eden popping out on demand. :FNP
Thanks so much for the kudos and I'm pleased that you get it! If you ever get your rocket bike, check out "Oldys" custom composites for killer fenders and Charles Tonna at Cuztom Kraft for tail lights. As far as the Genie goes, you're on your own!
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby bdosborn » Fri Feb 01, 2019 8:44 am
Hey, look what just showed up in my recommended videos:
And who am I kidding, I would get the 5kW too. Overkill is the thrill. 8)
Images: 506
Re: The Astroliner
Postby Atomic77 » Fri Feb 01, 2019 8:52 am
bdosborn wrote:Hey, look what just showed up in my recommended videos:
"Overkill is the Thrill" I laughed outloud Bruce. Also, I'm amazed at the Euro Van Culture. Until I started watching these Diesel Heater vids, I had no idea.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Fri Feb 01, 2019 9:45 am
Bruce, I'm wondering where you put your fuel tank. I originally thought inside hidden in the compartment. But I dreamed I was filling it and spilled fuel everywhere. Must be my subconscious saying "don't."
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby OP827 » Fri Feb 01, 2019 12:10 pm
I would consider location outside, so you do not have diesel smell inside camper. The tank must have a small vent hole in any case. Also the fuel pump is making clicking noise, so locating it outside to reduce noise when you sleep is not a bad idea..
OP827
Images: 378
Re: The Astroliner
Postby Atomic77 » Fri Feb 01, 2019 12:16 pm
OP827 wrote:I would consider location outside, so you do not have diesel smell inside camper. The tank must have a small vent hole in any case. Also the fuel pump is making clicking noise, so locating it outside to reduce noise when you sleep is not a bad idea..
Oleg! Where you been my friend? Did you get my pm?
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Fri Feb 01, 2019 1:11 pm
Ok... trigger officially pulled on the heater. Might be awhile before it's up and running but I'll update when it is
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby bdosborn » Fri Feb 01, 2019 3:25 pm
Atomic77 wrote:Bruce, I'm wondering where you put your fuel tank. I originally thought inside hidden in the compartment. But I dreamed I was filling it and spilled fuel everywhere. Must be my subconscious saying "don't."
I put mine in the tongue box. I have a diesel truck so I can fill both tanks if I pull up to the pump in the right way.
Images: 506
Re: The Astroliner
Postby Atomic77 » Fri Feb 01, 2019 3:28 pm
I still don't have a tongue box but good reason for me to get one made I suppose
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby featherliteCT1 » Fri Feb 01, 2019 7:49 pm
Did you buy the same unit shown in the Amazon link you posted?
featherliteCT1
Re: The Astroliner
Postby Atomic77 » Fri Feb 01, 2019 7:51 pm
Here's what I got:
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Fri Feb 01, 2019 7:52 pm
And here's the link:
5KW 12V Diesel Air Heater 10L Tank Vent Caravan Motor-Homes Pipe LCD Thermostat Monitor + Silencer Bus Van https://www.amazon.com/dp/B07JB7QZWZ/re ... vCbA8ST642
As Bruce said, 2kw might be enough. But I noticed that 2kw is 2kw, 5kw is 2kw-5kw and the 8kw is 5kw-8kw which would never go low enough for my space. So i went with the 5. I also joined the fb page and have learned a lot already.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby OP827 » Sat Feb 02, 2019 1:43 pm
I am around Michael :), just sent you a PM.
OP827
Images: 378
Users browsing this forum: Google [Bot], mountainminded and 3 guests
