OP827 wrote:Posted a short video on youtube showing how the lifting roof works
- Thanks DaddyJeep! The reliability of the lifting mechanism is also important.DaddyJeep wrote:I watched you video... That thing lifts fast. Nicely done.
OP827 wrote:Jim, thanks for the compliments on the build.
I ended up re-using central lifting screw from a donor tent trailer. I started with electric actuator and it worked, but I wanted to reduce the risk of failure and switched to mechanical only part for this single point vulnerability component. I do not have photos of the internals of the lifting mechanism and cable system, but I hope it will be clear enough from description below. The central lead screw pulls the pulley to double the speed of cable pull towards all four corner cables. I ran all cables inside the cabin along the walls to protect them from elements and then hidden them in plywood trays so there is nothing that can get there and jam. Each cable has a turn buckle for fine adjustments. Routing of cables really is not important as long as they position the lifting roof properly. I used sliding door metal pulleys and turn buckles from big box store to run all the cables and then custom-made brackets to fix the pulleys to trailer floor or walls. I answered similar question in the YouTube video, link in my signature below. The idea of the lifting mechanism is old, there are some links in the video comments to give you the ideas. You will have to size the cable to match your loads and then size the pulleys to make the aircraft cable last longer as it requires a minimal bending radius for certain amount of bending cycles, Google it. Let me know if you have further questions.
Users browsing this forum: No registered users and 32 guests
